Salta al contenuto principale
A collection of guides and support to help with washer repair.
3473 Domande Visualizza tutte
GE washer model GTUP240EM1WW won't lock
I was doing a load of laundry and the washing machine was thrown off balance. So I stopped the machine and tried to rebalance the load. When I went to go start the spin cycle the lid won't lock. It makes five clicking noises and nothing happens. I put it into diagnostics mode and it says there's no errors.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Unplug the machine for 5 minutes to allow it to reset.
Plug it back in and see if the code persists
5 flashes - Clear code and if problem still exist replace motor.
Punteggio 1
@cccorliss27 I know that you said you ran a diagnostics test, this is just to make sure that we are all on the same page. Run the test according to the manual. If nothing else you will also want to look at the washer control board on connector J4 to see if there are any issues with the lid switch.
Punteggio 1
3 Commenti:
Where exactly is the control board?
da
Yours is a wisher dryer combo correct? Let me see if I have that complete manual for you to get to the board.
da
That is correct.
da
Aggiungi la tua risposta
Charles corliss sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,369
