Salta al contenuto principale
couldn't access the bios?
Hello everyone i am trying to fix my acer aspire v5-431 but i couldn't access my bios to format it i have tried everything else mention over previous threads but nothing worked for me..!!All it does is starts with acer logo and after a while suddenly gives blue screen death issue.i have attached few images any help would be highly appreciated thank you!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
Have you tried pressing F2 on start up?
Punteggio 1
Hello
Try to remove the battery for 30 mn then put it back switch on and see if is okay
Punteggio 0
2 Commenti:
you mean bios battery or power batter?
da
I have done that , but still the same problem
da
This answer by Michaeleangelo for similar problem but for V5-471, helped me to resolve. Just short two pins under G2101 (clear CMOS) to restart BIOS, you will find it on motherboard under RAM closer to laptop edge. If not helped then try to update your BIOS to your latest firmware BIOS firmwares official Acer support. Then I was able to invoke BIOS by pressing F2 at the start of laptop.
Punteggio 0
Aggiungi la tua risposta
Krishna Shakya sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 963
