Salta al contenuto principale
Microsoft's third-generation Xbox game console, released November 22, 2013.
637 Domande Visualizza tutte
Why is it not reading my xbox one disc?
I bought this Xbox off of Ebay, and there weren't any warnings in the description of any problems. Unfortunately, i ran into one. I recently bought a brand new Battlefield 1 game, and I tried to play it. It didnt work. I ejected it and inserted it again to listen to it. The disc drive starts, then stops, for about 4 times until it gives up . I experimented with a xbox 360 disc, and the disc drive has no problem reading it and playing it. I tried this with four other 360 games and other xbox one games, and the same results occured. Any help?
Questa è una buona domanda?
Punteggio 0
Commenti:
Ok thanks. Just to know, what would be the correct way to replace the optical drive? Can i just swap out the old one?
da
looks like this guide Sostituzione lettore CD Xbox One should work for you
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
When you say you tried it on 4 other 360 games, and other Xbox One games and got the same result do you mean they worked or didn't work like the Battlefield disk?
If Battlefield 1 is the only one that's not working I'd say it's got to be a disk problem and you should try and return it/exchange it. I've had a game disk and DVD get scratched up and my Xbox One just spins and tries to play it but can't.
Punteggio 1
Commenti:
No, the other xbox one games didnt work either. I tried them on a friends console and they worked fine
da
@jtuck52 use your buyer protection from Ebay to return your Xbox. It will not get better and most likely will get worse. Somebody tried to poke you in the eye. Most likely issue here is a failed optical drive. Best person to ask would be @tronicsfix the console guru
Punteggio 1
Commenti:
Yes, send it back for a refund on Ebay. It's most likely a laser issue. Many times they will get to where they read some discs but not all of them.
da
Try This:
https://support.xbox.com/en-US/xbox-one/...
If that doesn't work, you may have to replace the disc drive or reinstall the firmware.
Punteggio 0
Aggiungi la tua risposta
James Tucker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 7,870
