Commonly faults like one side doesn’t work or doesn’t charge, etc. means one problem - broken internal cable which connects both sides together. As the charger board(in the right) and battery(in the left) are situated in opposite sides, (also joystick on the left side). All these works trough 10 wire cable which connects earcups and provides all functions.
According this, any of these 10 can lose contact so the problems appeared can vary around sound issues, button issues, charging issues and connectivity issues.
For me, biggest challenge is how to find proper cable which is similar in size and quality to genuine.
10 wires inside are separately isolated conductors, covered by some paint without plastic isolation. Like simple 3 wire headphone’s cable but 10 wire.
So if anyone have a link for such cable, people’ll say a lot of thanks, as i see it’s weak part of construction and could appear often. All I could found on AliExpress - 9wire.
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
