Is my laptop's logic board dead?
Hello, I have tried to repair my 2010 MacBook, I'm not the best at fixing things. I took apart and re-assembled my MacBook, there was a lot of dust and a bit of corrosion. It's clean now but when I turn it, I get the one beep code, which means the RAM isn't recognized. I'm using 8gb of 1067 mhz corsair RAM that works in my mid2010 white unibody MacBook fine. I tried other RAM and the same thing happened. Any help would be appreciated.
I also tried reseting the PRAM and SMC. Sometimes the fan will rev up and the screen won't show anything, sometimes the fan is fine but I get the beeping issue. There was slight bit of water damage on the board I believe but I cleaned up all of the corrosion and the LSI stickers are white, so I'm not sure if its dead or not.
Questa è una buona domanda?
1 Commento
okay so one do you get a green light on the power adapter, Two do you get fan spin...maybe something is shorting out somewhere .. do you get a screen??
da Matt
