Salta al contenuto principale
Modello A1502 con processore Intel dual core da 2,4, 2,6 o 2,8 GHz. Sul mercato dall'ottobre 2013.
552 Domande Visualizza tutte
Won't turn on even when the MagSafe is plugged in.
Won't turn on even when the MagSafe is plugged in. This is a new MagSafe that had been working. Laptop just stopped working. Is this a hardware issue that could be repaired?
Update (06/08/2017)
It is a ME864LL/A 128GB. I am not aware of any water and or drop damage. I have the back off and do not see any obvious signs. The MagSafe MD565LL/A was from the Online Apple Store and was bought 8/16. This is happened this spring not prior to new MagSafe. There is a thought that it could be the part on the inside of the computer that the MagSafe connects too. I look forward to your reply.
Questa è una buona domanda?
Punteggio 1
1 Commento
Please give us your exact model as they have been making these sine 2012. Please tell us the history of malfunctions including any spills and impacts. Seems like you bought a new mag-safe, was the same thing going on with the old one. Is the new one Apple branded or a knockoff?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Here's how to replace the mag-safe board: Sostituzione scheda MagSafe DC-In MacBook Pro 13" Display Retina Late 2013
Here's the replacement part: MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board
Immagine MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board
Prodotto
$14.99
Punteggio 2
When you plug the MagSafe adapter in, you should see a green light come on the connector. If not, try it on another Macbook. If it works, then probably the MagSafe port on your Mac is probably bad.
Punteggio 0
1 Commento:
How do I replace the port on the Mac? I do not have another Mac with the same type of connector to try on another Mac.
da
Aggiungi la tua risposta
Mary Brown sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 183
