Salta al contenuto principale
Sony Camera model number A5000, released Jan 7, 2014.
Lens says it's not attached properly
There's a message on my camera saying "cannot recognize lens attach lens properly" it's perfectly attached so I'm not sure what's wrong.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Your lens is probably damaged. Check the connections on the back of the lens . make sure they are not corroded
You may be able to clean the contacts with an eraser.
Good luck.
Punteggio 2
1 Commento:
Wnen I said "damaged" what I really meant was, the contacts were likely dirty or corroded. My fix still works, but you can also use denatured alcohol and or Deoxit if they are really bad
da
Aggiungi la tua risposta
Anabelle Trujillo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,312
