Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
iPhone 7 home button doesnt do anything after screen replacement
I had a customer come in with a cracked iPhone 7 Screen. Replaced it and swapped everything over, after testing initial replacement screen. When plugging it back in, the phone went into boot mode and wouldnt get past the apple logo and would continue to restart. So I unplugged it, unplugged battery again, tested a new lcd and it started right up again. After completely reinstalling everything on the new screen, and getting it together, the home button would not work.
There were no messages like I've seen in other threads saying "your home button might have an issue", the only thing it said was "unable to activate touch id". I uninstalled everything again thinking I had faulty home button extension cables on the replacement screens I had, and reinstalled everything on the original screen and same issue. Now at this point I just thought maybe i had damaged all the flex cables, So I had overnighted another order of screens and same thing on the new one. Any thoughts?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It's your parts. Either you have bad parts? Or your supplier let out some bad parts in your last order
Punteggio 1
Risposta Più Utile
sounds like the cable on the screen is faulty
and you may have possibly damaged the original screen cable when you removed the button
those buttons are very fragile and open to easily getting damaged on removal
if your new screens come and still same issue put original screen on a send them back to apple with a refund
Punteggio 2
Aggiungi la tua risposta
matt mocciola sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 183
