Salta al contenuto principale
La saldatura è un metodo di connessione di due pezzi di metallo sciogliendo un metallo d'apporto fra di essi. Ci sono molti tipi di saldature, ma questo articolo è stato scritto per insegnarti le basi della saldatura elettrica.
56 Domande Visualizza tutte
I want to buy a soldering station, but I don't know if this will be a
So I want to get into microsoldering, just basic things.
Long story short, will this soldering station be fine?
https://eustore.ifixit.com/en/Tools/Sold...
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It looks like a decent quality soldering station (I haven't used one though, just going on appearances). However, you will not be able to do a lot of micro-soldering with this setup as the tips are just too big. It will be fine for "soldering" through hole components.
Fo "micro-soldering", you need smaller tips or preferably micro-tweezers so that you can heat both sides of the smaller SMD components. You could look at the QUICK236ESD which has a nice range of tips.
Another option to consider is a hot air station. That will also allow you to do SMD passives as well as micro-BGA. The Quick 861DW station is well rated.
Of course, you could get the higher-end and higher cost professional stations like Hakko, JBC, PACE etc but the Quick products tend to be well rated and not too costly.
Punteggio 4
3 Commenti:
So is this for Europe too? I live in the Netherlands and I can't ship everything.
da
You'll have to look at the Quick website to see who distributes their products in Europe. Aliexpress also sells these as well.
da
Thank you very much!
da
For basic soldering. That would be perfect. Even soldering smd, is still possible. If your talking about soldering really tiny things, then you might want something different, but for basic jobs and basic things, its fine.
Punteggio 1
1 Commento:
Thank you for the advise, I will keep that in mind when making my purchase.
da
Aggiungi la tua risposta
Stijn Helmonds sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 180
