After replacing iPhone 3GS Dock Connector: Antenna Signal is Weak
I just replace the Dock Connector on my iPhone 3GS. Everything seems to be working fine but I'm getting weak GSM Edge and 3G signal.
I read iPhone 3GS Replaced dock assembly wifi good but very weak GSM Edge 3G, and verified that all the screw are in place correctly and the white bit that came with the antenna is were the do not remove sticker was. However, I'm still getting weak signal.
There's a copper tab on the antenna, is that supposed to come in contact with the case bezel (ie does it use the case bezel as an extension of the antenna)?
Also, doe's anyone have any other ideas on what may be causing this problem?
Questa è una buona domanda?
