Salta al contenuto principale
Steering wheel wobble an steering block noises
Steering wheel started wobbling then ther was a nocking noise under bonnet everything is solid well maintained I think it's the steering block
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
shawnqueeley Its time to replace the steering fluid in the rack . This video will help https://www.youtube.com/watch?v=Iev1xIr3.... I cannot stress enough USE HONDA POWER STEERING FLUID. Regular steering fluid is too thick and will cause problems . Hope this helps
Punteggio 2
check your tires for bulges or uneven (snaky) tread, loose lug nuts, bent rims. Also check the steering fluid level and drive belt tension.
Punteggio 0
Aggiungi la tua risposta
shawnqueeley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 193
