Salta al contenuto principale
Toyota ha lanciato la serie Camry XV30 2002-2006 come berlina di dimensioni maggiori nel settembre 2001 per il modello dell'anno 2002.
The clutch will not engage at all I'm wondering is it a slave cylinder
2002 Toyota Camry CSI
The clutch when engaged or disengage with the purpl
The clutch does not drive the car forward and is not over reving & no clutch plate smell is coming from the gear box and I was wondering is it the slave cylinder buggered, or is the clutch that is needing replacing.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
@timothymoad ,Timothy, Look to see if the pin from the clutch fork to the slave cylinder is sitting somewhat loose/has a little movement(not extended) when clutch peddle is not pushed, if some what free/movement then the slave is not stuck on and would suggest the problem lays further in the system. Probable clutch disc/pressure plate either worn or hanging up on bearing/fork. If things feel some what normal and the vehicle does not want to move,may be a broken CV joint on the axle. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Immagine
Punteggio 3
Aggiungi la tua risposta
Timothy Moad sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 7
Tutti i Tempi: 2,051
