Salta al contenuto principale
LeapFrog Leapster learning system, older model with stylus pen.
Where can I get my device repaired?
Can anyone PLEASE let me know where I can get my device repaired?!?!
Questa è una buona domanda?
Punteggio 3
12 Commenti
Hi,
What is the problem with your device?
da
Yeah I got it for $7 at a goodwill. Just wanted to see if I could fix it. The main issue is that batteries were left in it that leaked over a long time...
da
I remember when I had one of those.
da
@ah1234 on here we try and help you fix your own device. You are empowered!
da
Well lmk how?
da
Mostra 7 altri commenti
Aggiungi un commento
1 Risposta
Soluzione prescelta
@ah1234 sounds like the battery contacts may have either been to destroyed by the alkalinity of the old batteires or just not making good contact with the rest of the Leapster. You can clean the contact with some vinegar on a cotton swab (may have to repeat this a couple of times depending on how bad they look). Once properly cleaned check to see if you have better results with new batteries. If not, then you will have to open the leapfrog. Try the instructions from here. Take plenty of picture while you do so. You need those to reassemble the device and/or make a guide for the rest of us by following these steps. you can also post those images with your question, by using this guide so we can see what you see.
Punteggio 6
1 Commento:
My son's LeapPad 3 the screen keeps displaying that it needs to be updated buy a computer we try to update it and it did not work where can I take it to get it fixed
da
Aggiungi la tua risposta
A H sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 40
Tutti i Tempi: 933
