Salta al contenuto principale
Announced on July 2015, this is Motorola's flagship phone. It has a 21 mega pixel camera with a 5.7 inch IPS TFT LCD screen with a resolution of 1440 x 2560 making it Quad HD. Model number XT1570, XT1579, XT1575 and XT1578.
Battery charging issues. Recognizes it but doesn't charge.
Alright, I've posted a similar question, but that one got lost in the abyss that is tech problems.
Alright, so a few months ago i dropped my moto x and the screen shattered. I got all the parts, fixed it, and the screen is functioning like normal. The main problem is that the battery will drain extremely quickly, and the phone will not charge. The phone recognizes the cord as plugged in, but the battery menu says not charging. I have tried two phone chargers, both do not work. I have cleared cache, soft reset, and still nothing. The front flash is also missing, which i was thinking might cause the battery to discharge quickly. I have already replaced the battery, and it still has the same problem. I am beginning to think that it might be a charger port problem, or maybe even a problem with the logic board. (maybe even flash? who knows?)
Also if anyone has a good suggestion in how to glue the screen to the frame of the phone that would be great thanks. (1mm 2 sided tape is not doing the job)
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Did you find a solution? I'm facing the same problem! Thanks
Punteggio 0
2 Commenti:
Sorry no, I've brought my phone to a store and they said they couldn't fix it. Even if it was a problem with the logic board, I don't have the tools to fix it.
da
Thank you for the answer!
da
I have the same problem too, when i tried to get fixed in service center, its too expensive. So if you guys have any solution, post it here.
Punteggio 0
Aggiungi la tua risposta
H4N2 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 708
