Salta al contenuto principale
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
84 Domande Visualizza tutte
3DS won't turn on, charging light turns off after a few seconds
Okay so my friend gave me this busted New 3DS (the non-XL model) and we fixed it except for one part, and I ended up frying the button board by being lazy and putting the battery in backwards while avoiding closing the case all the way to test it. I replaced it, everything worked fine, then I gave up on fixing the HOME button, and pulled out the foam I had been using to try to push the ribbon cable clasp down. As soon as I did that, it stopped turning on, and I'm getting the same symptoms as when I had fried the button board: power button doesn't do anything, charging light turns on but doesn't stay on for more than a few seconds. Battery had been fully charged when it had been charging.
It can't be that I fried the board again, I didn't do anything that could have done that. I'm not sure where to test it with my multimeter to see if I did blow a fuse somehow.
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi, I also have his problem. What can I do? I replaced the top screen and I reassembled the device, connected EVERYTHING and it did not want to power on anymore but the orange light stays forever.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
If you placed the battery with wrong polarity you blow one the power line fuses (F1 or F2).
Just replace it and it will be 100% functional.
Regards,
Juan
Punteggio 1
1 Commento:
Where are those fuses located? They don't seem to be labeled.
The thing is, I blew the fuse on my old board, then replaced it. I didn't put the battery in wrong with this one, and I did nothing between it working and not working that would have blown a fuse, as far as I know. I'd like to confirm that a fuse got blown somehow before I go buy a second replacement one of these.
da
Aggiungi la tua risposta
Rika sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 4,299
