Salta al contenuto principale
Introduced on August 23rd, 2007, the Nikon D300 is a 12.3 megapixel semi-professional DX format digital single lens reflex camera produced by Nikon Corporation.
15 Domande Visualizza tutte
won't turn on through battery grip
nikon d300 won't power up from battery grip without battery grip works ok
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
  • Always check the battery first; it is the most common culprit with a dead camera. Is the battery charged? Is the battery inserted correctly? Are the battery's metal connectors clean? (If not, you can use a soft cloth to remove any grime from the connectors.) Are there any particles or foreign objects in the battery compartment that could prevent a good connection?
  • ith most Nikon point and shoot cameras, you can press a "monitor" button or a "display" button that will place the shooting settings and information on the display screen. Repeatedly pressing this button will cause different information to appear on the screen or will remove all shooting data from the screen.
  • Check more solutions from Nikon d300 Manual.
Punteggio 0
Aggiungi la tua risposta
John Hayes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 429
