Why is my power button not working but eject button is working?
My power button is not working but either way when I press the eject button it turns on.. what should I do? pls do reply
Questa è una buona domanda?
on Xbox 360 system if the power is not on, pressing the eject button will turn it on so that the Xbox can go through the ejecting process. it probably means your power button is broken. as long as you don't mind using the eject button...that is a workaround. a better solution is to use the button on your controller to turn power on and off. if you don't have a controller that is linked to your Xbox, turn it on using the eject button and then go through the linking process to pair your controller.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 527
