There is no sound coming from my iPod
If I plug in my headphones into the ipod I can then hear all the sound I want from any game or music but when I take out the headphones, there is no sound at all. Why me?
Questa è una buona domanda?
Lindy, your question about the Why me? Let me assure you, you are not the only one ;) try this and see if it works.
Try resetting your iPod Touch by pressing the Home button and the Sleep/Wake button at the same time. This is a pretty standard fix for most things that go wrong with the iPod Touch and before you go ahead and try anything else, this might solve your problem. If however, it doesn’t, then the little headphone control inside your iPod Touch is probably stuck.
Inside of your iPod Touch, there’s a tiny little controller that gets pushed over when the headphones are in, and comes back out when the headphones are not. This tells the iPod Touch what mode you’re in, and how you want to listen to your iPod. But sometimes, that controller gets pushed in when you insert your headphone jack, and it doesn’t slide back out when you pull the jack out. The only real solution is to put your headphone jack in a couple of times and then take it out. Continue doing this several times and see if that helps the problem.
Unfortunately if this still doesn’t fix the problem with your iPod Touch’s external speakers, you might haveto repair it, just let us know what works and what does not....good luck.
Aaaaauuuggghhh! you don't know how badly I want to open it on my own! LOL Thanks for both advices and it will still not work. I bow down to you and I will take it to someone to repair it only because I don't want to break it or something LOL. Once again, THANK YOU very much. . . :)
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 12,609
