Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
iPhone 5s water damage, gets warm but won't turn on
so i have 2 water damaged iphones 5s that won't turn on and seen by itunes. already cleaned with alchol, changed battery but no result. quess there are parts shortened. but i don't know where to look. will be grateful for help
Questa è una buona domanda?
Punteggio 0
2 Commenti
Sounds like they are done. Probably no fixing these, sorry
da
They will be if nobody says me components to check)
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Well, first let's stop putting electricity into these devices. Second let's find a good repair shop in your area that has an ultrasonic bath and does board level repair work. Or if you don't/can't find one in your area, iPad Rehab does the best work in the country and has an amazing mail in service. I do appreciate that you tried cleaning it with IP yourself first. But sounds like a tooth brush isn't gonna take this time
EDIT: Again the ultrasonic bath with bransonic, or an equal quality electronics cleaner with distilled water is the best solution. Before going microsoldering. Test a known good battery, lightning dock, and display. Yes, read what you wrote, you charged a battery
Punteggio 2
3 Commenti:
I am the service and I am from Italy. Cleaning does not help as I've said before, need some more concrete answers about components on motherboard to check
da
Ok. Cleaning with alcohol is not the same as cleaning with an ultrasonic bath. If you are a board level repair shop you'll want to use your multimeter to test continuity on the u2ic and maybe the pmic
da
Thanks! u2 is ok, will look pmic
da
Aggiungi la tua risposta
iloveclipse sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 301
