Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Touch ID works but home button doesn't
My iPhone got water damage and it stopped working then once I got it working again my Touch ID worked but my home button did not, switched backplate and flex cable and also the home button itself and it still did not work I assume the issue is with the motherboard but i don't know where to start. Any suggestions?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I'd double check and clean the connectors on the original home button. Only the original will give you Touch ID function. So try a new home button extension flex with the (cleaned) original home button. If that doesn't work, it's either board level or the the home button itself is damaged.
Punteggio 1
Risposta Più Utile
I would add that may be some of the filters near the home button FPC on the top of the board or the FPC connector on the home button flex itself is corroded and a bit of flux and soldering can fix those and get Touch ID back to work again. But must be tackled by someone with micro-soldering tools and skills. Definitely not DYI.
Punteggio 2
Aggiungi la tua risposta
Robert Warnock sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 487
