Absolutely no sound from Ipad 2
After battery, digitizer, and widi antenna replacement sound no longer works from headphone jack or speakers
Questa è una buona domanda?
Try cleaning the charging port, sometimes it gets oxidized and gives such fault. If you can replace it with a working one it would be even better.
I will try a new chare port
Unfortunately that did not seem to fix the issue. I ordered new speakers and headphone jack assembly
I'm a bit skeptical that will fix the issue, but there isn't much else left apart from a problem on the board itself. Hope you will succeed.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 812
1 Commento
Did verify conn before putting digitizer on
da Bradley Crawford
