My golf cart wont charge?
Our golf cart wont charge, seems to be a problem with the socket on the cart where the charger goes in??
Questa è una buona domanda?
Why do you think its a problem with the socket?
If your cart uses lead batterys like they usually do, they go bad in about 4 years. Check the voltage on the battery. You might have multiple 6v or 12 volt batterys and you should check the voltage on each of them. If a 12v battery shows voltage under 12v, its trash.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 63
