Salta al contenuto principale
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
373 Domande Visualizza tutte
Disassembled my N3ds XL, some black screen issues.
Hello guys! I just disassembled a bricked New 3ds XL that I just bought to change its motherboard. After reassembling it, powered it on and voila! It was working, although the top screen was black. I thought I may have had some ribbon unplugged, so I just started all over.
After reassembling it for the 2nd, 3rd and 4th time, the top screen works flawlessly but the bottom screen doesn't. Im kinda new to this, so I don't really now which exact ribbon is the one that powers the bottom screen, and I don't want to disassemble it many more times to avoid damaging the new board, Could you give me a hand? <3
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@strongal ,Strongal, I am hoping the links below to disassembly guides may help you. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Nintendo 3DS XL 2015 Teardown
New Nintendo 3DS XL
Punteggio 3
6 Commenti:
Hello! I've already read both of them and didnt find an answer there, unfortunately :/
If you could only point out which of the ribbons or wires is the one that gives power to the bottom screen, I could try and solve it !
da
Strongal, below is a link to a bottom replacement screen showing the ribbon cable and power wire connectors. let me know if it helps.
http://www.ebay.com/itm/Replacement-Lowe...?
da
God, I didnt think of that solution D:
The 3ds is at my gf's house, but now I know which wire I exactly need to check, thank you so much!!
da
Strongal, Perfect, thanks for replying back, good luck with your 3DS XL.
da
A last question, I managed to fix the bottom screen display (thank you sooo much!!) but the touch screen is not working.
It should be related to the smaller ribbon from that replacement, right?
da
Mostra 1 altro commento
Aggiungi la tua risposta
Strongal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 3,032
