My phone has lines going through it plus water damage
My cellphone has vertical lines going through it, and a little bit of water damage but everything still works buying a new screen should fix it right?
Questa è una buona domanda?
You may be lucky but typically, the water is inside the phone, on the logic board and under the shields, even under the IC's. The real problem is the corrosion that is taking place as the water evaporates. Powering on the phone accelerates the process. The longer you let a phone stay wet, the more time you are giving corrosion to damage your logic board. The saltier or harder the water is, the more damage will occur.
Your phone may "work" now but it will likely fail in the near future.
You should do the following asap:
A professional repair shop that does water damage repair can decontaminate your phone because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board if any problems pop up.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 5,369
