Part of display flickers
A part of my display flickers.
If you would divide the screen into 5 columns, one of them, the second to the right, flickers heavily. Not all the time, but most of the time.
Sometimes shifting the screen can make it go away (coincidence?) or reduce it to a bright flickering. Usually, it is a flickering of black and white boxes and lines. The working lines in that area are half shifted to the right.
I guess because the flickering can go away, that it is due to the display or a cable. But the video card could also be the reason.
Does anyone had a similar issue and got it fixed?
Questa è una buona domanda?
2 Commenti
Hi,
Try connecting an external monitor and check its' display. If it is OK that eliminates the GPU as the problem.
If the above is OK then you can concentrate on either the video cable or the screen.
da jayeff
I have problem with acer v5 573g. I can hear when windows load, but screen is black. Laptop have 2 graphics cards intel and nvidia. I tried to connect it to an external monitor via hdmi but nothing happened. The battery was removed and all attempts to reset did not help. Above all, the upper left corner of the display had colored vertical lines. It seemed as if it had been broken, but not. The laptop was not used for 6 weeks. One day I decided to check it out, everything was OK, but the next day the picture just disappeared.
da Stanislav Drosanski
