Salta al contenuto principale
Il top di gamma Huawei nel 2016. Basato su un case unibody, ha una doppia fotocamera posteriore sviluppata in collaborazione con Leica. Può avere 32 o 64 GB di memoria interna e sei diverse finiture esterne. I numeri di modello sono EVA-L29, EVA-L19 ed EVA-L09.
20 Domande Visualizza tutte
P9 turns on but screen doesn't light on
So my phone has stopped "working". The last days that i could use the phone there were some errors ( apps closing and bugging). But one morning i waked up and the screen won't turn on.
But when you hit the powerbutton the phone vibrates and makes sound..
So what could be wrong?
The screen? but its strange because there are no breaks in the glass..
Thank you guys
Questa è una buona domanda?
Punteggio 1
1 Commento
Try holding volume down when you boot it up if that works you will see a menu go to factory reset using the volume buttons and hit the power button (this will wipe your phone, photos music the lot!) and if you cant get into that menu than sorry sounds like the mother board is toast.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
I've been having hard freezing issues most likely due to filling up phone storage.
Use power and volume down hold for 15 seconds to force shutoff and turn on automatically.
Punteggio 3
1 Commento:
I have been having this problem for about a week. It seems to be worse if the phone is warm/hot. Is there a thermal safety sensor that turns off the screen light? I can still see it if I hold it in bright sunlight. The force reset doesn't always make any difference.
da
When i set the brightness of my Phone higher than my screen turns black. I am using it on the most low position right now. In daylight i nearly see anything.
I think it is a proximity sensor problem… But it is not possible to find this part on the market…
I dont know if this is the same issue as you have?….
Punteggio 0
2 Commenti:
I also have the same issue
da
It might be the backlight
da
Aggiungi la tua risposta
Jan Pecquet sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 8,975
