My iPhone 6S Stuck on Apple Logo
My iPhone 6S was stuck on Apple logo for 2 hours during software update. How to get the phone back to normal?
Questa è una buona domanda?
If you're still seeing the Apple logo and nothing else has worked, there's a problem booting up your iPhone. DFU, or Device Firmware Update, Mode stops your iPhone from booting up all the way so that you can connect it to iTunes and restore the iPhone and start fresh.
maybe DFU will solve "iPhone stuck in Apple logo"
I will give it a try, thx
I have tried everything. I even tried rebooting from iTunes but I am getting an error message stating that my phone cannot be found.
I've tried all 3 methods itll go off but if i turn it back apple logo still there,Gonna send it to sellar, I have apps and info on it what can i do.. Iphone6sPlus stuck on apple logo In Oklahoma...
My iPhone 6 s is stuck on the apple logo too and how do I fix it so I can text and listen to music at the same time.
@idkyouth How are you doing? How can I fix my Phone that is stuck on the apple logo.
There is a way though so make sure you follow these instructions carefully:
1. Hold the home and power buttons down together
2. The Apple logo should disappear from your screen
3. After a couple of minutes it should reappear – when it does, release the buttons
4. Quickly hold them both down again until your device goes off
5. Plug the USB cable into your computer (not to your device yet)
6. Hold the Home button down and plug the cable to your device
7. When you see the Connect to iTunes screen, release the button
8. iTunes will open and the Device in Recovery message will appear
Click on Restore
If the method can't fix your problem, you may try this tool.
Very helpful. This worked. Thanks a ton for the answer.
Does this work without data loss?
i dont have a macboook bruh are you kiding me
You will have to get the iPhone to boot recovery mode and do an update through iTunes. Do not select restore or it will wipe all data on the phone as well. If you don't mind losing data then choose restore which has a higher chance of working.
More info here:
Pressed the buttons as the post says, still stuck on apple logo
I mean either way you lose your data
You can restore your iPhone on 3uTools.
But you need to make your iPhone enter DFU mode or recovery mode, then you can flash your iPhone.
iPhone stuck on Apple logo (also called white Apple or white Apple logo screen of death) is a common issue that most iPhone users meet. If you are just facing the same situation, don’t worry, here this post will explain why iPhone or iPad frozen on Apple logo, and exactly how to solve this problem.
If your iPhone stuck on the apple logo during update, one of the easiest ways to fix this problem is forcing restart it. For iPhone 6S and earlier models, just press the "Home" button and "Sleep/Wake" button. Keep holding the buttons until you see the Apple logo. This will take about 10 seconds.
If the method mentioned above doesn’t work, you could also try to put your iPhone in DFU mode and restore it with iTunes. DFU will completely restore the device and erase all the data from your phone.
Source with more solutions: https://www.imyfone.com/iphone-issues/fi...
Try rebooting it at first i.e press and hold the power and the home button together for 10 seconds. If that does not work connect the phone to your computer and open up iTunes if it detects your phone try to restore (it will clear up all your data).
If both that above techniques fail then you will have to go to DFU mode by the following process to fix iPhone stuck on Apple logo
Connect to the computer
Turn off your phone
Hold the power button for 3 seconds
Hold both the power and home button for 10 seconds
Release the power button but keep holding the home button for 15 seconds
Itunes will then alert you that your phone is in recovery mode
Follow the instruction in iTunes to restore your phone.
What can cause iPhone 6S stuck on Apple logo? Jailbreak/ iOS update/Hardware
The simplest method: fix iPhone 6S stuck on Apple logo by hard reset.
Hold Power button (on the right side of iPhone 6/6+/6s/6s+ and on the top of iPhone 4/4s/5/5s/5c) and Home button (the round button of the center) simultaneously until you see the Apple logo.
Simply, hold these buttons for 20-30 seconds. Leave it as it is for the half hour. And if you are lucky, this is going to work like a charm. For most people this method doesn't work.
You will try to restore your Apple 6S to factory settings if restart can't get rid of the issue. But you should be careful before doing this.
Factory resetting will help to handle the white Apple screen of death situation, it would cause data loss on your device. So well, in order to retrieve data that have been lost in the process of fixing the iPhone stuck at Apple logo issue, you are strongly recommended to deal with such problem with professional third-party iPhone data recovery tool
You are coming very close to get some repercussion from your habitual spamming. You are always linking to the same site which makes your answers spam. Be advised!
If your iPhone has been stuck on Apple logo and not moving forward, then we got three sure solutions for you to get rid of this problem. How to Fix an iPhone Stuck on Apple Logo
If your device turns on but gets stuck during start up
If you see the Apple logo or a red or blue screen during startup, try these steps:
Connect your device to a computer and open iTunes. If you don't have a computer, try to borrow one, or go to an Apple Store or Apple Authorized Service Provider for help.
While your device is connected, force it to restart.
On an iPhone 6s and earlier, iPad, or iPod touch: Press and hold both the Home and the Top (or Side) buttons at the same time. Keep holding them until you see the recovery-mode screen.
Don't release the buttons when you see the Apple logo. Keep holding until you see the recovery mode screen.
Select Update in iTunes.
I have a computer.
Thanks for the tip on how to fix my phone that is stuck on the apple logo.
WHAT IF HOME BUTTON DOESN'T WORK . i couldn't find a work around that,
Well, I'm pretty sure this has been mentioned but your best bet is to visit an Apple Store & they'vegot some better tools than we, the general public. They're going to do the same basic idea as your iPhone needs a “hard reset" & I apologize for not being able to give you a better answer but you might as well deal with the reality of the situation. Based on the date of this open ? I want to assume you've always done the needful but I wanted to see this thread have a happy ending. Good luck & I'm pretty confident this will turn out “ok" for you & your iPhone!
Ultime 24 Ore: 35
Ultimi 7 Giorni: 124
Ultimi 30 Giorni: 385
Tutti i Tempi: 341,839
9 Commenti
i try and try but it says its going to reastore it but it just goes back to the apple logo again and does the loop and stays like that
https://is.gd/ONMFZb
da Hurchong
Your method is useless. I try many times. It can't solve the problem. This helped a lot.
Steps to Fix iPhone Stuck on Apple Logo Issue
da AnnetteCassidy
Actually Apple has provided the solution to the error, https://support.apple.com/en-us/HT201412.
And there is much easier method to resolve this problem. https://www.minitool.com/ios-recovery/ip...
da Piter
Select Update on iTunes.
da chicadita
I cant coz iv tried but not letting me
da Richard
Mostra altri 4 commenti
