Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
Home button was working but not now
The home button was working fine but suddenly fingerprint stop working and home button too. So I have to use ASSISTIVE TOUCH.
Every single home button that I replace the finger is not working.
So how can I make the fingerprint working again?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@albertoh ,alberto, Info. from the troubleshooting guide link below. As a security feature, your home button's embedded Touch ID fingerprint sensor is uniquely paired to your iPhone's logic board at the factory. If the original home button assembly is replaced, damaged, or disconnected, Touch ID features will cease to function. If your original home button is salvageable, clean the connector and retry it. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
iPhone 6s Plus Troubleshooting
Punteggio 1
2 Commenti:
So fingerprint won't work after replacing home button no more?
da
alberto houtmann, Sorry, no it will not, only the original button will, it was paired to the phone at the factory.
da
Aggiungi la tua risposta
alberto houtmann sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 92
