Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
I replaced the charging port and it still won't charge
I replaced the charging port and it still wont charge. before the replacement I cleaned out the charging port with a q tip and a little isopropyl alcohol which made it so i could charge it only at a certin angle. any ideas?
Questa è una buona domanda?
Punteggio 0
3 Commenti
what percent is the isopropyl alcohol
da
you make it sound like the alcohol got past the port and got on to something else like an exposed wire
da
I replaced it with another charging port and still no luck
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
A phone that wont charge could be caused by multiple things:
  1. A defective battery. The iPhone 6S is well know to suffer from battery issues, perhaps your 6S Plus has a similar problem.
  2. A defective charge port. While you replaced it, these small parts are notorious for poor quality and you may have gotten a bad one.
  3. Debris or oil residues inside the port (you cleaned it with IPA already).
  4. Defective Lightning cables and charging bricks. Always use genuine Apple cables and bricks when troubleshooting problems.
  5. Finally, a defective charge circuit on the logic board. This could be caused by water damage, impacts, poor quality (i.e. the cheap stuff) Lightning cables and charging bricks, especially the "automotive" ones.
The first 4 you can troubleshoot yourself and the last one requires a micro-soldering repair (not DIY).
Punteggio 4
Have you tried another cable/plug?
It is possible to have a faulty charging port which you have bought. (I've gone through 3 in a row before!)
No debris in the connection from the port to the board.
Punteggio 2
Replace tristar ic your problem will go ago.
Punteggio 0
Aggiungi la tua risposta
cobynew sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 58
Tutti i Tempi: 2,441
