MacBook won't boot up sometimes
My mac book won't boot up after shutdown for long periods. The service guy told the issue is with keyboard and replaced the keyboard. But the issue is not yet resolved, it works sometimes and it won't boot up first time in the morning after being shut down for more than 5/6 hrs.
Questa è una buona domanda?
4 Commenti
Do you think that the problem is related to the macbook's temperature or because of time? If only happens when it is cold, i automaticly think in a solder of smd component at the logic board. Big trouble.
da Mac o PC
Maybe, I am not sure. It appears only when it is off for 5/6 hours or more than that. Already paid 200$ for keyboard replacement and issue is reoccurring :(
da krans
Try to locate an independent Apple repair shop near you. If they repair logic boards will help you more, beause they will understand the problem.
da Mac o PC
Hi, @ krans
I have exactly the same problem. (A1502, early 2015)
on your macbook Keyboard-replacement wasn't succesfull.
In my case i replaced the touchpad-cable -> no succes.
I can exclude an software-problem, I have tryed a older Mac-Version, mac os sierra and also installed macos mojave clean.
What is the actual situation with your A1502?
it just boots by chance, i would say in 20 % of all tries, when it boots it just works fine there are no problems, also the diagnosis from apple with hitting the d button when booting said there are no problems. mostly it wont boot, and its not usable with that damage.
i'm afraid too that in the workshop they'll replace such as the keyboard with no effect and it becomes very expensive.
do they replace small components at the workshop or just the main-parts?
da Joachim Seifert
