1066 vs. 1600 - Which one can I use?
I've currently got 4GB and would like to upgrade to 8GB.
1066 mhz 2x 4GB
or
1600 mhz 2x 4GB
Is my MacBook comptabile with the 1600 and is this the best/fastest option?
Questa è una buona domanda?
1066 mhz 2x 4GB
or
1600 mhz 2x 4GB
Here's Apple's upgrade page: MacBook Pro: How to remove or install memory
As you can see Apple states: PC3-12800 DDR3 1600 MHz as what the system needs. It will also support 1600 MHz RAM but it won't offer much improvement.
If you want performance you'll want to look at upgrading the HD to a SSHD or better yet a SSD.
Thanks for the feedback, I think a start will be the RAM.
My MacBook I mid 2010 I think it can only take 1066 MHz?
Please correct me if I'm wrong!
''MacBook Pro (15-inch, Mid 2010), MacBook Pro (15-inch, 2.53GHz Mid 2009), MacBook Pro (15-inch, Mid 2009)
Number of memory slots 2
Base memory 4 GB
Maximum memory 8 GB
Memory card specifications - Double Data Rate Small Outline Dual Inline Memory Module (DDR3) format
- 30mm (1.18 inch)
- 2 GB or 4 GB
- 204-pin
- PC3-8500 DDR3 1066 MHz type RAM
Additional notes For best performance, fill both memory slots, installing an equal memory module in each slot.''
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 719
