Blue Screen on iMac
after grey screen computer hangs on blue screen.
Questa è una buona domanda?
It is not completing the boot sequence. See if it will boot from the original system installation disk. If so, go to the second screen pull down menu to Utilities -> disk utility and see if you can repair the hard drive.
UPDATE
Here's a list of serial numbers on the machines that have capacitor problems.
Does your computer fall into this group?
Serial Number ranges:
W8435xxxxxx – W8522xxxxxx
QP435xxxxxx – QP522xxxxxx
CK435xxxxxx – CK522xxxxxx
YD435xxxxxx – YD522xxxxxx
+ great information
Yes indeed. The serial number is W8444xxxxxx. Is this important?
This machine falls into the bad capacitor issue group. Open the unit and inspect the capacitors for swelling and/or corrosion. Poor luck has been had with replacing these caps. Power supply replacement will generally keep the machine running for another year if it goes first. To know the problem look at the diagnostic LEDs on the motherboard. There is a wealth of information on this site about this issue, do a search for capacitor. also check at www.jimwarholic.com
Insert your restore disk and try to run a diagnostic on the hardware. Sounds like your harddrive might be dying on you.
After doing that it says, video RAM problem.
Then your Video RAM aka Graphics card has gone bad
Could be the old iMac G5 capacitor problem. Use search on other posts regarding this topic.
I think it is my logic board.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,189
