Salta al contenuto principale
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
160 Domande Visualizza tutte
My Ps Vita Wont Turn on! tried everything
So When i plug it in To Charge It Shows The Solid orange Light But it stays like that i try to turn it on but it doesnt turn on At all It doesnt blink or anything It just shows the orange light.and Also i got the Call of Duty Bundle and i havnt charged it for Like 2 years Or 1 Could that be the issue ?
Questa è una buona domanda?
Punteggio 1
1 Commento:
I've had my vita for 6 years about now. Haven't turned it on for a while but now it chooses to die on me, do I replace the battery?
da
Aggiungi un commento
2 Risposte
it could be an issue that the battery is stagnant and you would have to excite it.
To excite a battery, you need an external power source set at the input of your charger. pump the current directly to the prongs of your battery for approximately 30 seconds, then try charging again.
If this fails, then you should try shorting the power button traces of your device. the traces should be shorted for about 1 second to finalize a power connection. if it works, the device should boot up as if you turned the device on normally.
If this is not working, try replacing the battery
If that doesnt work, then the board is likely failing.
Punteggio 0
Have you tried replacing the battery or checking if you can hold it for 30 seconds?
Punteggio 0
Aggiungi la tua risposta
Kevin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,344
