My sceeen won't continue to turn on.
My phone actually turns on but then it kept on stopping on its logo and never continue to turn on to the actual home screen. What is the solution for this problem?
Questa è una buona domanda?
Hi,
Try a hard reset on the phone.
Be aware that a hard reset will erase all your data and downloaded apps. It will restore the phone to its' factory default condition or its' last successfully updated condition.
Before you perform a hard reset, ensure that the battery is fully charged, that the charger is removed from the phone and the the external SD Card (if any inserted), is removed.
Here is a link that show what to do.
Be patient, it takes a little while for the reset to complete.
The hard reset option isn't showing.
Hi,
What does happen when you press the Volume Up button, hold it while pressing the Power button and then keep holding both together?
Do you get the Alcatel Splash screen, followed by a quick view of the Android logo and then the recovery options or nothing?
I think the volume up button of my phone is broken. Are there other solutions?
Hi,
The only solution is to fix the Volume button if you think that it is faulty and then try the reset procedure.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,329
2 Commenti
it wont turn on but it will charge
da Destany Robinson
Mine smartflip won't turn on either
da Debra Maloney
