Salta al contenuto principale
The GoPro Hero5 Black is an HD waterproof action camera released by GoPro in October of 2016. The 4k resolution video camera has voice control, a touch screen display, and built in WiFi.
84 Domande Visualizza tutte
Why is my GoPro Hero 5 keeps on hang, can't review the pictures?
Why is my GoPro Hero 5 keeps on hang, can't review the pictures even if I have it connect on my Phone, still displays on "Loading" only until it is batter empty.
Questa è una buona domanda?
Punteggio 0
1 Commento
Tried to hold on ti MENU but nothing happened. If only I can send video here....
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
If your camera is currently frozen, try to reset the camera by holding the MODE button for 10 seconds (hold the top SHUTTER button on the HERO Session / HERO4 Session).
Should the camera not prompt a reset, remove and then reinsert the battery to get it unstuck (for cameras with integrated batteries, Step 1 will imitate a battery pull).
Make sure you have the most current software on your camera.
Punteggio 0
Risposta Più Utile
Hello,
I used to have the same problem and I solved by changing the micro SD card.
I had a Samsung one that was giving me lots of issues.
I hope it helps.
Regards
Ricardo
Punteggio 1
1 Commento:
Thank you! It will help. I will try your suggestion cause the sd card given to me was also Samsung. Thank you again
da
Still, not prompt a reset. Even if its connected to phone to view the pictures easy. We need to remove the bat just to reset it or turn it off.
Punteggio 0
That sucks though. Is there some simple troubleshooting or tricks to fix this? Im sure their support will have something to say about the issue. Before buying an action camera, I make sure they have good support.
Punteggio 0
Aggiungi la tua risposta
Jenina Artus sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 9,638
