Salta al contenuto principale
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 Domande Visualizza tutte
Camry Ignition Switch Removal
So I have a 1994 Toyota Camry 4 Cylinder. It is currently having some issues and im trying to replace the ignition switch not the lock cylinder and i got the first part detached but the other part that connects higher i have no idea how to get to it as i dont want to mess anything up.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi Michael,
The link below should help you get that ignition switch swapped out.
How to change key ignition switch
Punteggio 3
How to change ignition switch on a 94Toyotacamry
Punteggio 2
Aggiungi la tua risposta
Michael sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 38
Tutti i Tempi: 4,192
