Laptop not turning on
My laptop was working fine last night and I put it on my table before bed and when I woke up it didn't want to turn on. I thought it was out of charge so I checked by holding down, no indicator. I thought the brightness might be too low, no result. I connected the charger and it charged. But it did not turn on. I clicked the caps lock no light tried turning on again no result. Help please.
Questa è una buona domanda?
1 Commento
Does it sound like the fan is spinning when you press the power button, do you hear a chime too?
If you do, and the caps lock is not lighting up, it is not passing POST, which will most likely be a logic board issue. If it is not doing anything, try @mayer suggestion. If it boots when the charger is plugged in, after disconnecting or reconnecting the battery, it will narrow the issue down to the keyboard, trackpad cable or trackpad.
da Reece
