Salta al contenuto principale
Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
493 Domande Visualizza tutte
when I press the gas nothing happens
replaced the battery solenoid valve and voltage regulator still nothing when I press the gas?
Questa è una buona domanda?
Punteggio 1
3 Commenti:
mg101474 what make and model is it and what have you checked thus far?
da
Its a 2006 yamaha g22.
I've already replaced the battery voltage regulator and solenoid valve.
Next I'm going to try the accelerator switch and the key switch
da
I have a g2 1990 that I have the same problem I know there is no spark in the plug
da
Aggiungi un commento
1 Risposta
Here is a link to wiring diagrams: http://www.courtesygolfcars.com/yamaha-s.... They have both the G22A and G22E. Before spending more money on parts, I would take a multimeter and start checking components.
For example, do you get continuity when the key is turned in the key switch, and do you lose continuity when you turn the key off. If so, then there is no need to spend money on the key switch.
Punteggio 0
Aggiungi la tua risposta
mg101474 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,207
