Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1623 Domande Visualizza tutte
Bench Mark TEST review
https://browser.geekbench.com/v4/cpu/198...
https://browser.geekbench.com/v4/compute...
does this look all good????
Questa è una buona domanda?
Punteggio 0
6 Commenti
What do you mean by good here? Good is somewhat subjective depending on how you are looking at this.
What are you comparing it to and what is the reason for the concern?
da
Is it normal speed for a stock CPU a Samsung ego 500gb SSD and curicial 16 gb ram upgrade two 8 gb ram cards?
da
What Evo? 960, 850, 950, etc.
da
Did you try another benchmark service? There may be something wrong with that one. Does you computer actually feel slow?
da
No it's pretty fast I was just wondering if it's ok cause the numbers EVO 850
da
Mostra 1 altro commento
Aggiungi un commento
1 Risposta
Soluzione Prescelta
No it does not look good. It's running at least than half of what it should.
See the standard Geekbench scores here:
Geekbench 2 (32): 6690 Geekbench 2 (64): 7323
Geekbench 3 (32): 2530 Geekbench 3 (32): 5106
Geekbench 3 (64): 2781 Geekbench 3 (64): 5689
http://www.everymac.com/systems/apple/ma...
Punteggio 4
3 Commenti:
What would cause that??? It's new with a 500gb SSD and two crucial 8gb ram cards. It also has only 70gb taken on the drive
da
I would replace the HD SATA cable. These cables have wear issues which can impact performance. Here's the IFIXIT guide to replace it: MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement and the cable you need: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
da
I called Apple and I'm gonna have them check it out Monday. Computer speed feels fine. I used geek bench v4 to run the test
da
Aggiungi la tua risposta
Collin.nesbitt@gmail.com sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 122
