Why wont my continental crank over?
My car won't start. Battery is good.
Questa è una buona domanda?
Here's the tale and question of my fight and final solution for this issue:
Anyone know what fusible link part number I need -solved alternator
It might be your starter, or fuel pump. When you try to start your car does it seem like its trying and just doesn't turn over or does it just make a grinding or clicking sound and thats it. Also check your fuel pump. Look in your manual for the location of the fuel pump relay or fuse and try replacing the relay or fuse with one that is good. If it still doesn't crank over your fuel pump could be dead or there is another issue.
Hope this helps and good luck fixing!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 451
1 Commento
terry mozell this is a big problem that you do not give us enough information about. What engine size? What type of transmission? What does it or does it not do? Turn over or not turn over? How do you know the battery is good? what else have you checked? Did this just start? What happened to your Lincoln prior to this starting? The more information you provide, the greater the chance of getting a helpful answer.
da oldturkey03
