Salta al contenuto principale
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Domande Visualizza tutte
Older PS3 stuck updating and can't go into safe mode.
I have an older PS3 (It was a gift, I don't know the hard drive size.), and the disk drive does not work. Until I get around to repairing the drive I was going to give it to my mother for watching Netflix.Unfortunately, when I connected it to the internet it began the update, and then it had an error, and will not go into safe mode.
I would like to know how I could remove the hard drive and reformat it so that it will be past the update problem.
Is that possible? and how would I go about that?
Questa è una buona domanda?
Punteggio 11
Aggiungi un commento
13 Risposte
Soluzione Prescelta
yes it is possible....follow this guide for removal and instillation. Sostituzione disco rigido PlayStation 3 after the drive is removed if you have a computer with an extra sata power connector and data cable you can power down your system plug it in and boot your system. you can also use an extra external enclosure if you have one. now this is the tricky part...if the hdd is a 32gb or smaller you can use windows to format it (FAT32)...if it is larger than 32gb us this program http://www.ranish.com/part/ use version 2.43 (i have never used it but it was recomended on a forum).....after you reinstall the hdd it should be a simple follow the instructions on screen...make sure you have a jump drive fromated fat32 as well with the latest ps3 update that you can download here http://us.playstation.com/support/system...
i hope this helps
Good Luck,
Cody
Punteggio 6
4 Commenti:
Ok, I have reformatted the disk, the PS3 prompts me to use a mass storage device
(in this case my re-formatted USB(FAT32) with the current PS3 update in a file marked update, that is in a file marked PS3)
It says checking pleas wait, and I wait and wait and do not get any further. Suggestions?
PS: I couldn't get the ranish to work, but the device manager worked fine.
da
hnmm that should have done it.... try looking in this forum it seems like they are having the same problem you are. I appologize for the above not working.
Good Luck i hope that forum can help,
Cody
da
@gatewaynomad U needed to also make folder UPDATE all folders and update file IF ALL folders and files are same size u ROCK
It should update and play on
da
I keep getting the error code that says mantins then why I can sign on soon as I enable hen I cant
da
Risposta Più Utile
I fixed my nephews PS3 that had a similar problem, as soon as you turned it on it would go straight into the update only to hang about half way into updating and give an error code. There was also another person on here with the same problem and I told them how I got around this problem. You do not need to reformat the drive or loose any of your data or connect it to a computer. Check out the post here:
I am getting error code (8002F147) on my PS3
All I did to get rid of the error was to remove the HDD then turn on the PS3 "WITHOUT" the HDD then when you get the "missing hard drive error code" insert the HDD. Then turn off the PS3, then turn the PS3 back on and be patient just let the update run. I do not know why or how this worked but it worked for me. Good luck!!!
Punteggio 8
5 Commenti:
I had the same problem did exactly what u stated and it work thanks so much ur a godsend
da
Wow! Had the same problem and it worked like a charm! Thank you very much!
da
it didnt work at all... neither of the "fixes"
da
best solution, it worked !
da
Only solution that worked thanks
da
If you are updating your o/s make sure everything is working on your PS3, i.e disk drive not working will get you stuck on the update page. Hope this helps!!
Punteggio 3
3 Commenti:
I believe that any hardware error will get you hung up during the update. I think most common error is the BR drive error.
da
This solved my problem, faulty bluray drive connector. Only valid fix I found on the internet. Thanks Buddy
da
your the man. it was a cable not plugged in all the way on the disk drive. ps3 works again
da
your bt/wifi card is $@$*/broken.
id suggest you call sony, but then theyll tell you to send your ps3 in requiring $100 - $500 and so they can go f$ck themselves.
So the only option left is to unplug playstation and do what i did:
P1SS SH1T PUNCH HAMMER THE PIECE OF SH1T IN AND FINALLY SMASH IT ON THE GROUND AND CRY.
Punteggio 1
I'm getting error code 8002F002 can anyone help
Punteggio 1
Make sure your wifi/memory card daughtercard is completely connected. If the ribbon cable is not fully inserted, you can get the failure you describe.
Punteggio 0
the hard drive cover on the left side take it off remove blue screw pull tab and out comes the hard drive i had a problem like that with mine i downloaded a program called miniaide fat32 formatter and i hooked my hard drive up to my computer and formated it and wipe it with the program and it will say unallocated space and the i put it in my ps3 entered safe mode and sytem updated didnt freeze like normal and it worked after trying hundred of trial and error of other things fixed my problem hopefully can fix yours.
Punteggio 0
your update file should be in all capital letters or ps wont see/reckognize it
Punteggio 0
@XnriquX Thank you so much :D that fixed my ps3 that I thought was gone forever :D
Punteggio 0
I have error code 8002f1f9 and it does the update automatically, it gets to 99% and then the error code appears. Also I can't access safe mode. Help
Punteggio 0
1 Commento:
Hi, having exactly the same issue, get the error code around 50%, restart, updates right when I turn it on, cant get into safe mode. Did you find a solution?
da
I have the same problem the shorty23
Punteggio 0
To get into safe mode take out the drive and power on th ps3. Hold the button til it beeps 1 then 2 times the letgo when it asks for you to hit the ps button do it and your in safe mode.
Punteggio 0
3 Commenti:
no safe mode on 8002f1f9 error. just starts and try to update and error all the time
da
Pull hard drive with console unplugged, plugg in and turn on wait for error no hard drive , NOW UNPLUG console insert hdd reconnect power and you should update if not start at beginning WHEN you insert hdd try too start in safe mode follow instructions and cross your FINGERS best of luck
da
Have had luck with this (BUT US AS A LAST RESORT) start by unplugging system, pull HDD! plug in turn on wait when U get no HDD error, plugg HDD in and quickly disconnect SYSTEM ,,,,reconnect power start safe mode and follow best route to resolve took me 4 TIME'S
da
It just goes back to the update man please
Punteggio 0
1 Commento:
If u have removed and replaced the hdd have u tryed using safe mode and USB UPDATE MAKE SURE U have same amount of data on USB as file has mine keeps coming up 4 bits less than originally on the original file and folders hope you have better luck with it (using Sony update and no matter same result 4 mb's of data short and it says corrupt file and puts me back in update ) :(this is a friend's PS3) this time same beginning different ending no matter what still trying have faith it will happen
da
Aggiungi la tua risposta
gatewaynomad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 61
Ultimi 30 Giorni: 295
Tutti i Tempi: 113,300
