Salta al contenuto principale
The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
82 Domande Visualizza tutte
says paper jammed or out of paper but its incorrect no jam and do have
says paper jam but no jam
Questa è una buona domanda?
Punteggio 3
1 Commento:
I have a WF- 2540 should say WTF as it always has been a pain since it was new....Aways says I'm out of paper...I am not and have filled and filled again adjusted and filled again...no luck
da
Aggiungi un commento
1 Risposta
Hey!
The reason an electronic circuit will say that the device is jammed, while its not, is because it is being mechanically tricked, or it's software is failing. Software failure is very uncommon on printers, as you are rarely updating it.
Disassembling the Paper feed, then reassembling it will fix your issue if there is no damaged parts.
Punteggio 0
4 Commenti:
But it's a brand new printer Epson 442 and l don't want to take it back has when it did print they where brilliant
da
Keeps saying paper jamme
da
I am fed up of this problem
da
is there a firmware update available for the device?
This link uses a different model as an example. but shows you how to get a firmware update
https://www.youtube.com/watch?v=75kQa1Om...
da
Aggiungi la tua risposta
Deborah Raker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,726
