Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
iPhone 6 Completely Dead and Unresponsive
I am a Smart Phone repairer and I recently had an iPhone 6 dropped off to me for repair. The problem description given by the customer was simply that the phone was unresponsive.
I proceeded to examine the phone and tried all the suggested fixes, Changing the LCD/Digitizer, Battery, and Charging Port. I also tried a hard reset, cleaning the connectors with 98% isopropyl alcohol.
It isn't being recognized by iTunes at all and there is no display showing (Even with no ambient light) I've tried everything I can think of short of replacing the logic board and it is completely unresponsive.
The owner did say that the phone had been repaired and looked at by multiple other phone repairers before bringing it to me.
What are the possible causes and solutions to this problem.
Thanks in advance
Stelios Sgoutas
Easy Tech Repairs Adelaide.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There is most likely a problem on the logic board. Are you capable of diagnosing board level issues?
If so, I would start by testing checking the water damage indicators. If there is no water damage, then the main voltage rails (PP_BATT_VCC, PP_VCC_MAIN) to see if there any shorts. That's just to start...you could always come back and comment on your findings.
If you are not comfortable doing this, then I suggest you find a repair shop that does micro-soldering repairs.
Punteggio 4
Aggiungi la tua risposta
Stelios Sgoutas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 768
