Salta al contenuto principale
The Panasonic LUMIX DMC-LX100 is a compact digital camera with 12.8 MP resolution, 4K HD video capabilities, and Wi-Fi access. It was released in November 2014.
Lock sign on the screen
There is "Lock" sign appeared on the screen and the control wheel does not work, which means I can't change wb, iso, or metering. It never happened before.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Joohee Lee from the owners manual "●When the cursor button is locked, operation of the cursor button, [MENU/SET] button, and control dial is disabled. To enable operation, press the function button again."
you can download the user manual from here
Punteggio 2
1 Commento:
Thanks for help. When I click the FN 1 botton again it says 'cursor botton lock canceled' but the Lock sign is still on and the control wheel still does not work. I went to the menu and made sure the control ring is on DEFLT. Still the same.
da
Aggiungi la tua risposta
Joohee Lee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,598
