Salta al contenuto principale
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
162 Domande Visualizza tutte
Playstation Vita won't charge.
Playstation Vita won't charge. When plugged in a solid orange charging light appears for about a minute, followed by a single blue flash then no light. With the Vita on, you can see the icon does not reflect that it's charging.
I've tried 2 different charging cables.
Plugging into the Power Brick.
Plugging into PC with Vita in USB Power mode.
Nothing appears to work.
History: I recently replaced the battery myself. The replacement worked as the system works, but I have since noticed the charging issues mentioned above.
Any ideas?
Questa è una buona domanda?
Punteggio 2
1 Commento:
Did you replace the battery due to the problem or just replaced it due to normal use? If you did replace the battery for normal use you probably just need to replace your battery again because you probably just put in a defective battery. If you replaced the battery due to the charging problem you probably need a new Vita.
da
Aggiungi un commento
1 Risposta
Sounds like you need a new charging port
Punteggio 0
Aggiungi la tua risposta
ArcadeDemon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,943
