jubril olabode, Reset procedure to try:
1. Hold (menu) and (vol-) button on the side of the TV
2. while holding these, press the power button on the side of TV (NOT remote)
3. Blue light comes ON and stays ON
4. Wait 10 seconds then let go of (menu) and (vol-)
5. wait another 30 seconds and some type of picture should appear, If that does not work, unplug TV for 10 minutes and then hold power button on TV for 60 seconds, plug in and turn on
If this does not do it, take the back of the TV and check for possible bad power supply/capacitors on the boards or you may have to replace board. See video links below for more detailed info. Good luck.
https://www.youtube.com/watch?v=wEWzYLaK...
https://www.youtube.com/watch?v=tqvjkq5v...
Votato
Annulla
Punteggio
7
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
7 Commenti
Ln32c450e1d Samsung standby light not on TV won't turn on
da Chris Giannetti
Maybe yall can help me i have a Samsung un60j6200afxza t v first when i got it it was all blank no standby i replaced power control board and now i have standby but nothing works
da Mack jay
My Sinotec Tv does not display it only shows the red botton what can i do?
da Khuselwa
My Panasonic tv only red standby light nothing else what do I do
da Valerie Thompson
most of the modern lcd and led tv's when the standby light lights but the tv does not switch on especialy hisense samsung sansui etc .... means there is a problem on the power board and a leaking or dry electrolytic capacitor could be the culprit , so in most cases if you can work a soldering iron replace common capacitors like 1000uf 35v -470uf 35v -220uf 35v etc it could cost you a mere R30 rsa for the lot, also check on thatt same board for high voltage diodes that have a short circuit reading that prevents the power supply from switching on
Good luck
Smiley
da Ismail
Mostra altri 2 commenti
