Salta al contenuto principale
A 12.2-inch "prosumer" tablet released in February 2014. Powered by a custom version of Android 4.4 KitKat.
40 Domande Visualizza tutte
How do I fix the wifi, it won't turn on
When I move the setting to wifi on, it just turns grey. The same happens with Bluetooth
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@tbow2k ,Tom. I found a suggested fix from a forum 1st link below, remove battery, hold down power button 30 seconds, reinstall battery and power on.
Other things to check would to be up to date on firmware. Link #2 is Samsung trouble shooting on WiFi etc. where you can input info. and hopefully get a solution.
Factory reset is probably the last thing you want to try, last link explains the process. Good luck.
https://forum.xda-developers.com/galaxy-...
http://support-us.samsung.com/cyber/popu...
http://www.hardreset.info/devices/samsun...
Punteggio 1
Aggiungi la tua risposta
Tom Bowman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 978
