Salta al contenuto principale
Il tablet Surface Pro di quarta generazione, lanciato sul mercato il 26 ottobre 2015.
208 Domande Visualizza tutte
A light shadow on bottom of screen during system boot, is it normal?
Hello there,
I've bought this surface on 2015 December and latelly I've checked the screen during boot, while having a dark background a light shadow appears in bottom of the screen. Is it normal with this kind of screen? Is it any source of light?
I drop a image so you can look!
Thank you
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
8 Risposte
Soluzione Prescelta
I don't see the picture but I know exactly what you mean.
It means uneven pressure at the bottom of the screen. Unfortunately there's really nothing you can do about that.
You know when you apply too much pressure to a LCD screen display it causes temporary white marks?
E.g bent phone tablet frames are a common cause of this too.
While this is uncommon there are some new devices out there that exhibit this.
Or really it's just called backlight bleed in your case if the surface hasn't been repaired before.
It's a manufacturing imperfection which can appear in some devices.
Update: Here is some info about backlight bleed. It is a manufacturer defect on the screen which I would say is acceptable. Depends on the seller if they will do warranty replacement just because of backlight bleed.
http://www.tested.com/tech/584-how-to-sp...
Punteggio 4
4 Commenti:
I don't recall seeing this before, but the uneven pressure makes sense.. I hope it'll stick to that size and don't get bigger. For now it's not a problem :)
da
They usually stay that way unless the surface frame gets dented or bent.
da
Here's some more info again:
Yes, some types of backlight bleed can go away by itself. This is mostly pressure-related backlight bleed. If the front panel is uneven, panel tightened too hard into the bezel etc, then the pressure can cause backlight bleed. This can be an error from manufacturing level, or from transport and storage.
When you use the screen, then heat makes the material expand to some degree. When pressure is releaved, the backlight bleed caused by the pressure can disappear.
Source: https://hardforum.com/threads/does-backl...
Sorry for the long text but it's worth reading.
da
Thanks you again @benjamen50
da
I am experiencing the same issue, spot is perfectly centered on bottom screen, it appeared a few weeks ago after more than a year of use. Surface Pro 5th gen.
Uneven pressure would make sense although can’t think of any event that might have created this. Always had the keyboard protecting the screen when travelling. Wanted to share this for the sake of tracking the issue.
Punteggio 1
5 Commenti:
Exactly the same issue here. At exactly the same spot! Please update if you ever found a solution.
da
Same issue here, including a slightly less obvious mark of the same size to the left (same height) directly above the F5 text on the F5 key.
da
For the sake of tracking the issue, I just received my Surface Pro 7 and it has this issue, although it's not as noticeable as this picture. Also exactly in the center. Seems like a structural issue. I probably wouldn't have noticed it at all if I didn't inspect my screen very well.
da
same issue!! is there any solution to this?
da
@fti yess.. same spot !
da
I have had the same issue at my surface pro (2018). A circle of light bleed in the bottom center only visible at a black background. I thought it was just bad luck and lived with it. I have now changed to a new surface pro 6 and after a week I found the same issue. Extremely disappointing!
Punteggio 1
1 Commento:
Exactly the same issue here on the surface pro 5th Gen. In exactly the same spot! Were you able to get any further information on this issue?
da
I have the same issue on the surface pro 5th generation core i5, in exactly the same spot of the screen! I don’t think its a coincidence. Its a manufacturing defect that Microsoft will never own up to. Last time i’m ever buying a Microsoft device. Once I sell this, i’m getting an Ipad Pro. I’m done with Microsoft.
Punteggio 0
1 Commento:
I have the same thing.. was going to wait a while before getting it repaired under warranty.
da
same here right in center between F5 and F6 about 1.5cm above the bottom edge of LCD (Surface 6 Pro) - it appeared probably 3 months after purchase - its more visible with black backgrounds - iam glad other report this - so its probably not worth replacing the unit because there is a design flaw that will probably manifest same issue on EVERY unit sooner or later… well done Microsoft… butchering you only product that could ever compete with Apple in terms of design…
Punteggio 0
And also count this guy in :(
https://answers.microsoft.com/en-us/surf...
Punteggio 0
experiencing this right now with my surface pro 5.. it has been a few months only, but i guess it’s an issue for most microsoft users..kinda disappointing.
Punteggio 0
I want to say is Sep 2020, and my new surface pro 7 of three months is also exhibiting this issues, I’m better off just living with for now, hopefully it won’t spread and will be putting a protector on the screen to stop it from spreading
Punteggio 0
Aggiungi la tua risposta
Luís Jerónimo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 37
Tutti i Tempi: 12,826
