Salta al contenuto principale
L' Apple iPhone 5c è stato annunciato il 10 settembre 2013. La riparazione di questo dispositivo è simile ai modelli precedenti e richiede cacciaviti e strumenti vari. Disponibile nelle versioni: GSM o CDMA. In tagli di memoria da 8, 16, 32 GB. E nei colori: bianco, rosa, giallo, blu e verde.
1228 Domande Visualizza tutte
Blank modem firmware but has IMEI , replaced C23 + U1_RF
Originally no imei and blank modem firmware, found C23 was damaged and replaced it, IMEI returned and was working until a few days ago, stuck on searching, no modem firmware, replaced baseband chip (U1_RF) , but the modem firmware is still blank, any suggestions?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sounds like you don't know what you are doing.
U1_RF cannot be replaced alone, you need to replace the baseband flash as well because they are encrypted as a set. After that you need to use the serial number rewriting tool to rewrite the device serial number to match the IMEI that is programmed on the replcement U1_RF, otherwise the device cannot be activated.
Punteggio 2
Commenti:
Thanks mate, I didn't know they are encrypted as a set, why did the IMEI return when I replaced C23? I'm guessing that's because it's just a capacitor right?
da
I guess when you replace the cap, the baseband is repaired somehow, making it to respond to the OS, however since it is wrong, it does not work and theOS shows a cached value.
da
It was working when I replaced the cap, made and received calls, a few days later it was stuck on searching, blank modem firmware, that's when I replaced the baseband chip, incorrectly thinking that would fix the issue, how would I find the issue with this type of problem? What's the process? If you don't mind me asking
da
Aggiungi la tua risposta
Krayzee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 5,303
