Salta al contenuto principale
如何更换电池及拆解整部机?
请问大家!我的机那里出了问题??开不到机,插入直充电才可以开机,不过一下子就关机了,当一插入直充电,马上有反应,Lenovo名字跑出来,然后呢一下子跳去充电的画面,说电池里的电0%,然后又跳回去显示Lenovo名字,之后又跳去充电的画面,一直都重复这样,就是充不到电,也不能开机使用了。我怀疑是不是电池的问题! 先谢谢大家的回答!
How to replace the battery and disassemble the whole machine?
Excuse me, everyone! What's wrong with my machine? ? You can’t turn on the phone, just plug it in and charge it, but it shuts down immediately. When you plug it in, it immediately responds. The Lenovo name ran out, and then it jumped to the charging screen, saying that the battery’s power is 0. %, then jumped back to display the Lenovo name, and then jumped to the charging screen, and kept repeating this, even if the battery cannot be charged, it cannot be turned on. I doubt it is the battery problem! Thank you all for your answers in advance!
Questa è una buona domanda?
Punteggio 1
1 Commento
It is important to choose a standing desk for your home office. If you are someone that requires peace and quiet in order to be productive, try to find a space with little outside noise or with a door that can shut out distractions. Natural light can have a huge effect on motivation and energy levels, so try to set up your space near a window or in a well-lit room.https://www.fezibo.com/collections/stand...
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
尝试更换一块新的电池来解决问题。或者更换充电插头。
Try to replace the battery with a new one to solve the problem. Or replace the charging plug.
Punteggio 2
Aggiungi la tua risposta
ABBOT sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,084
